Need help...BIG task...2005 std cab box design for 2 DD T1510's
i took off the plastic because it rattles like crazy but there is a double wall the 14.5" height keeps you under it. if you go higher you have to notch out at least an inch but think it will need to be 1.5". but only if you go above 14.5"
like i said you only gain about .2 cu ft if you go higher than that and its a lot more work.
even if you go up to the window line which is 25 inches you cant get to the 4 cu ft mark i crunch the number for you
any ? just ask
im like 5' 10" so i dont think he will like it because i dont. plus you dont have much room to mount amps batteries ect. im thinking about going to one 10 or 2 eights just for a little room
ahhh yeah I'm kinda worried bout it too, but ehh we will see....Amps are small and will go under the seats...pdx4.100 for a reason:)
I am worried tho, so someone else chime in...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i took off the plastic because it rattles like crazy but there is a double wall the 14.5" height keeps you under it. if you go higher you have to notch out at least an inch but think it will need to be 1.5". but only if you go above 14.5" like i said you only gain about .2 cu ft if you go higher than that and its a lot more work.
any ? just ask
very much appreciate it, thanks sooooo much
anyone know how many aero's will do for 2 10's? 2 3" aeros?
he already got the tens, being shipped as we speak
keep them coming, and who is mike?
Mike465 is on this forum, he builds alotta boxes. (look at his threads of the box builds.) He also built a box for me and he is local to me. I will stand behind his work. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here is the link to my build i did a stealth design in my reg cab f-150 with subs on the passenger side and port driver side tuned at 34hz.
http://www.caraudio.com/forum/showthread.php?t=376882&page=3
da box king
da box king
Portland, MI
da box king
AJ (ACE)
    Jun 28, 2026
