Need help AsAp
checked all fuses, and how would i check that? im sorta a newb!i hooked stock back up and it works perfectly fine,
well then you are getting power and the other stereo isnt getting power...which is weird, your ground for your other head unit might be bad, check it with a dmm
your not hooked up to the right acc. red wire from the gmos-01 unit.you need to pull the deck out turn the key to the on position and find the right power wire .make sure it goes on and off with the key.
popeyeortiz
popeyeortiz
San Juan capistrano, CA
popeyeortiz
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
