need help asap
Sirrion
ok i blew my last set up subs up and i wnet to get new ones today...and i tested my buddys first to make sure that they worked and when i put mine on....i can't get the amp or my radio to turn on without touching the power wire to the REM wire....and i can't figure it out...plz help....
i replaced all fuses......power wire...the 2 on the amp the one in the radio and the one in the cars fuse block....and i can't see any wires that aren't hooked up....could it be a wire got striped?
amp does not turn on at all....unless i touch the power wire to the REM wire......but then my radio won't turn on at all either unless i thouch the power wire to the REM wire on the amp
Sirrion
Sirrion
Rushville, Ny
Sirrion
