need help asap...........
do you think that it could be the fuse?? cause when I first put the power cable on the battery terminal, it sparked alot, and the protections light came on, but then went off. Do you think that maybe I blew the fuse?
ok, so today, I double checked everything, I reconnected all of the wires, but when I reconnected the negative terminal on the battery, the protect light came on, and the car was off, not even power on. Any ideas? could it have been a bad ground
Disconnect the speakers & try again. Also I assume you checked the remote? It sounds like maybe the remote is seeing power even with the car off...?
If you get the same result with no speaker connections then my vote is bad amp too.
What you're describing would happen if the power/ground wires were reversed but I'm sure you wouldn't let that happen.
Hmm, if everything was off then the amp shouldn't care that you just reconnected the negative terminal. Any pics of the install...it's always better to have a visual...
BIGsherm7272
Tampa, FL
BIGsherm7272
