BIGsherm7272
Banned
well, I hooked up everything correctly, I t is hooked up to 2 JL 13W6v2's, at 1 ohm. I doubled checked the power, the ground, and everything else and still no power. Maybe has something to do with the remote??
Hmm, if everything was off then the amp shouldn't care that you just reconnected the negative terminal. Any pics of the install...it's always better to have a visual...ok, so today, I double checked everything, I reconnected all of the wires, but when I reconnected the negative terminal on the battery, the protect light came on, and the car was off, not even power on. Any ideas? could it have been a bad ground
