Need help asap with car audio wiring
I have a pioneer deck a clarion 7 band eq 2 kicker comps 2 kicker ks13 tweeters a 1000 watt amp nd a 500 watt amp for mids nd highs the deck only has one pair of outputs so i took an rca from there to the input on the eq nd from there i used the sub out and front and rear for speakers my question is how do i add a soundstream bx-10 bass processor to my setup?? How should i run my rca's ive tried goin from sub out to input on the epicenter then out to the amp but it sounds real bad so how would be the correct way to run my rca's nd hook all this up?? Please help! Thanks.
ill do the bass first from the H/U to the epicenter then from the epicenter to the EQ then to the bass amp the epicenter was design to be use with a full range signal
underfire i havee done tht but since the eq has sub level and then the epicenter has it to once i turn both up my subs distort alot nd sound bad bt i have to turn up the eq's sub level in order to hear the subs nd epicenter to. Or cld it b cuz their 12" comps? They can only handle 300 watts together nd their bridged to a 1000 watt amp and the epicenter could it be tht they cant handle?
Chris323 ive thought bout tht but since the eq only has one input tht means tht also my mids nd highs would b using the epicenter since their run off the eq as well or is this thought incorrect?
just take it out all together ,you dont need it if your running the eq
Yes i did its not connected right now b the thing is tht for rap nd hip hop its enough with jst the eq but sometimes i play mexican music to nd tht sometimes or most of the times needs more bass so thts where the epicenter comes in handy
Mendoza1126
Mendoza1126
Salinas, Ca.
Mendoza1126
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
