need help asap on car practical jokes
-put bbs in the valve stems of his tires and screw the cap half way on so it deflates them
- turn his rear plates upside down(or whatever plate he wont notice when he gets in)
-get a BUNCH of sand or dirt at walmart(not that expensive) and cover his entire car with it so it looks like a giant pile of dirt
-box his car in with cinderblocks(this will take a while and needs concrete to be done well)
- all of the above would be the best solution though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Take off his liscence plate and place a map or to where he can find his plats. and dont send him directly to his plates...send him to another map or another clue thatll send him to another to another and to another then finally he'll be able to find his plates that were underneath his truck or something all along.
window chalk every window of his car completely.
take all 4 tires off, car up on cinderblocks..and stack the tires next to his car.
if the car is unlocked..take off a door.
take the door latch mechanism out of his door..replace everything else perfectly.
super glue his actual horn completely (under hood)
pop off the section of his door panel where the window switches are, unplug ONE, replace.
adjust the striker in the door jam so it wont close flush
fill his car with packing peanuts and seran wrap the whole outside
disconnect his fuel pump
Rather than dragging a bunch of cinder blocks with you, drop the car onto the tires that you take off of it.
I also kinda liked the idea of unbolting the exhaust before the muffler.
hmmm... transmission fluid comes to mind.... sure does make a car smoke //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
throw a smoke bomb or 2 of the same color up in the exhaust as far as you can..maybe when it gets hot enough itll ignite the fuses?!
blong131
blong131
Emmaus, PA
Louisiana_CRX
