Need help, Arc Audio Kar 900.1D
kSwift
CA
Hey guys I need some help with my KAR 900.1D. Just picked it up a few days ago and it does not seem to be working right. When I first got it the amp played my subs flawlessly. Hitting all the notes, tested it on 4-5 songs. After I took it home to install it properly the amp did not seem to play right anymore. I have it hooked up to 2 dvc 4 ohm subs. It will power the subs and play the bass, but only when the gain is set really high. I took out the 2 subs and grabbed a sealed box vs my ported and played a song on there. Flawless bass hitting. But it was only 1 sub wired at 2 ohms. So I know the amp works fine because it played the 1 sub fine, but for some reason when i hook it up at 1 ohms it seems to be very distorted or not getting enough power. Im very confused. Some help would be appreciatced. Thanks guys.
Some pictures. RCA Cables seemed to be blacked out? Is that normal?
I used to have one of these, nice amps that's for sure. Def looks like it's gonna need some work though
what do you mean? is there anything wrong with it internally? because i am mind boggled right now. still a beginner to the car audio scene
Used. Worked like a champ the first 30 mins of play. Then did not work like how I wanted after. It seems like distortion is coming out of the speakers. re-wired the speakers. checked it all out. plays one speaker great at 2 ohms. its just at 1 ohms where they do not have the same output
Its called KAR 900.1D. There is only a Gain, Subsonic filter, and a low pass filter. No switch for mono or stereo. I really appreciate the support you guys are giving me. I am really disappointed by this purchase and getting really fed up with all the rewiring that I have done to get no where.
kSwift
kSwift
CA
radwilsons5803
