Need Factory Upgrade Advice
xingpao
5
USA
Ok, experts, here we go!
The vehicle in question is a 2012 Grand Cherokee with the 9 speaker + 8" sub package. I've found the entire system to be flat and generally void of any balance whatsoever. Obviously, it has to go!
Please give yourself a 3k budget and replace the following components (No HU replacement):
3.5" center
6x9" front doors
1" front tweeters
6.5" rear doors
2.5" rear pillars
506 watt 12 channel amp
8" sub
Only other caveats are I will likely go the JL Audio stealthbox 10" for the sub at $700, which would leave you $2300 for the rest.
Thanks in advance for the help, gentlemen...
are you sure it's 6x9's in the front doors and 6.5 in the rear? that seems backwards from what's normally in cars... but I haven't been in a newer jeep.
6x9s in front doors. Posted a link but apparently has to be moderator approved and they must be a week behind //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
12 channel amp? Gonna be hard to find that...
Well, obviously that is some foolishness Chrysler dreamed up. I'm just trying to replace the entire system into something with much better SQ and I'd like some advice around going active with that budget vs. passive and so on. Using a 6x9 component in the front is limiting to say the least. Is it worth going the $400 Imaging Dynamics route with that budget, etc? I see that using the HAT 6x9 in component mode may be a pain, but a bit cheaper. Do I give up some bass and go 6.5? Is going active and just ignoring that 3.5 center channel the way to go?
Those are the issues I'm hoping you gentlemen can help with. Thank you...
dont worry about the center channel, a couple of nice 4 channel amps and a mono block for the sub would be perfect.also i'd do the 6.5 components in the frt doors as they tend to sound a bit better . i could set you up with everything you need for this system
2 of these American Bass - PH-4100 FR-4 CHANNEL AMP 300 each shipped 600
American Bass - PH-2500 MD this 325 shipped 325
2 sets of these HD 61 A 260 each shipped 520
these AF 256/020 Accent Fill 175 shipped 175
with all the wires 120 -200 200
depending on which wires size wise ______
1820 plus paypal fees shipped
xingpao
xingpao
USA
mylows10
