need clarification
mrray13
uz some fegbags
ok, if you wire 2 dvc 4ohm subs parallel, that creates a 1ohm load correct?
don't it actually create a 2 ohm load that is then cut in half because of a bridged or mono block amp?
the reason for asking is simply a bet with my brother-in-law. we both agree on the 1ohm load, but not on how it gets there. neither one of us completely understands the math to figure ohm loads.
thnx in advance, and if at all possible, could someone explain it (the math) so i can print it and show him.
Okay here goes: you have two dvc 4 ohm subs. Wiring one in parallel creates one 2 ohm sub, so basically you have two 2 ohm subs, you then wire the 2 subs in parallel, which gives you 1-ohm load. The formula I came up with is: {(Sub1 (2-ohms))x(Sub2 (2-ohms))/(Sub1+ Sub2)}. So 2 subs divided by 2 ohms, gives you 1 ohm. I believe this is correct, but then again I could be wrong.
mrray13
uz some fegbags
mrray13
IL
Phatillusion
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
