need box spec help
rosrock
i need someone to help find the cubic feet and what itts tuned to. This is a dual 12 box but ill just give the one side. Its a aero port or flare what ever you call it. pics to explain it more
bottom depth 15.75", top depth 12.75", height 12", width 14.25", port length 12.25", port diameter 3.7/8", port white material "thickness" 1/8. 3/4 mdf. and these are all inside dimensions
What is 3.7/8?
If it's a 4" port, it's 1.3@41hz give or take. if it's 3" it's closer to 30hz. I assume it's 3/4" thick and a dual chamber box.
I came up with .99 and gave up because I **** at this. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Umm, I done it for you. That is if the dimensions you listed are internal. If they aren't then the box need to be tossed out because no 12" is going to perform worth a crap in it unless you seal it. Even if the measurements are internal its is a small space for most 12's ported.
It'd be close to that if the dimensions were external, but that couldn't be right....could it?
I assumed his measurements were external, man. It wouldn't be the first time someone used an enclosure that's WAY too small, right? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
rosrock
rosrock
saginaw, mi
AudioDave
vegang
vegang
