Need Box Help, First box build ever
zyliusilver
Hey guys! I need a little (a lot of) help building my very first custom box. First of all, I am making this box for a Cerwin Vega Stroker 12". This sub will be running at 1200w RMS. The sub requires 2.8 cubes and is recommended to be tuned at 35hz. I am trying my best to make a box to these exact specs. I have a 2004 Acura TL and this will be going in the trunk, sub and port back. I will be making this out of .75" MDF. I tried using WinISD but I had no idea what I was doing so I went to the less accurate RE Audio Box Calc. Don't mind the screenshot attached as it has the wrong dimensions on it. The box is slightly larger by a calculated amount for the double baffle and 45s. Any suggestions would be much appreciated! I can only work with 15" height and 30" width. Depth is the variable. Thanks!
Specs are as follows:
Width 30"
Height 15"
Depth 18"
Wood Thickness .75"
Port Height 13.5"
Port Width 3.25"
Port Length 1 14"
Port Length 2 8"
Total Port Length 27.625"
Box Volume 2.963Ft3 (About 2.8Ft3 with double baffle)
Tuned Frequency (Fb) 34.7 (35.7 with double baffle)
zyliusilver
zyliusilver
Pittsburgh
zyliusilver
