****need basic box design $$$
billabongcr
Yep
simple box
can be up to 38 inches wide, subs on either side, port in the middle.
2 Fi SSD 10s with copper coils and a zx1500.1
38hz, 2.5-3ft^3
17 inches tall max, keep it as short as possible
11-12 deep. subs will be mounted on the 11, upfiring. port will be also. (see pic)
smaller the box the better dimension wise, still maintaining airspace and freq.
subs and port firing up, like so:
(oolldd box: took a 20lb sledge to it)
except with port in the middle. EDIT: would like port to be bigger than 3in, preferably around 4 or bigger if can be done.
if at all possible, would like to keep only 2 port walls. one on each side straight down into the box. but if i absolutely have to, i can L it out:
quote me a price.
ive designed a few, and just not getting the right feeling after looking at my designs.
You could do something like
w=38
h=17
d=11
go with a 5 inch wide port should be tuned to around 32hz
i mean if you just want something simple that should work but you will probably get port noise
^^port noise with a 5in port?
and the 2 most important points of my specs are 38hz and 11 deep.
thanks anyways tho.
alright people. i just got my amp, so i have everything i need. i just need the box design.
ANYONE?? $$
You don't have enough space to get what you need without greating sacrificing port area. What the most you can do on height and width?
billabongcr
Yep
billabongcr
Florida
JDBuilder
