need at around 700 true rms at 2 ohms
Setting up a system in my girls car, i have two 350 rms explode subs, which are decent subs I've heard them before with a nice amp, right now I've got a planet audio amp that lies about it's rms (claims 2400) and only does 500 at 1 ohm. Well the subs are 4 ohm SVC so I have a 2 ohm load. Basically I need a budget amp that does 700 watts @2 ohms. I found a soundstream amp, or a couple actually that are around 130 for the right juice. If they don't lie about their numbers, anybody ever dyno a soundstream? Any other good amps for the same price? Suggestions? I like buying new equipment and she wants new stuff too. thanks for any help.
Thanks for the quick replies btw holy crap, but at 2 ohms that amp is probably closer to 300, which is barely enough for 1 sub. Are mb quart amps any good? She would be paying for it and that PA amp is mine so another reason I want to buy a new one online
JBL GTO-501EZ has been dyno tested to make over 700W at 2 ohms, if I recall correctly. Plus it has a simple gain setting method that is similar to DD-1. No need to feel iffy about the quality with this amp, or even the GTO-751EZ, but you'll have to spend a bit more for that one.
I'll look into. Does JBL make good amps? I've heard good things about Kenwood and hifonics and id rather just get a little bigger of an amp like 1000 so there's some room left over and I can really max out the subs, they're replaceable so I don't care if I blow em but I probably wont. I mean if we're already spending that much why not shoot a little high
If you hear kenwood and hifonics are good you are listening to the wrong people. Yes JBL makes very good amps
"For the price" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif i meant. Where can you get that amp for 210?
Used, I was offering to sell you one. I have a DC audio 3.5k coming in the mail tomorrow so no use for my brx 2400.1 anymore.
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
449
346
deondm18
deondm18
Minneapolis, Minnesota
Jeffdachef
    May 16, 2024
    May 16, 2024
