need amps for 4 15's
  • 4
i don't want anythign real expensive.i mean who wants to spend more on amps than they did the rest of the system?i was thinkin of those mtx 1000's 3 of the mwould power my complete system and they would def fit under the back seat.i was looking at some capacitors also with 3,000 watts.what do u guys think?
First off I would either sale the mtx's or the kicker and get the same all the way around but i think 4 MTX 1000ds would push all of them just fine. The kickers might be a little bit low on wattage but it would bang.
Actually it doesn't matter if you mix and match subs. That'll actualy help you out a little, where one set of subs lacks the others might make up for. Those MTX 1000d are a bit pricy so I'd sudgest 2 or more JBL 1200.1's, excelent power all the way down to 1 ohm and won't make you go broke. You might wanna look at http://www.ikesound.com good prices and free shipping.
123
If they have been sitting in their boxes, they should be fine. Exposure to the elements (sun, dirty air, air conditoning) are more...
Well I’m on the gp website and I’m looking and I found the one I’m going to get but I’m unsure if the length I should get. Standard is 4ft should...
10
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I would recommend starting with the Big3 kit.....I prefer the 2/0ga kit but for a couple $s less the 1/0 kit will do just fine...
nelson
nelson
In my MTX custom sub box
bootleg
    May 12, 2024
Brendon Jenness
    May 11, 2024
