Need amplifier help
I'm getting two fi audio q 12's for my ford excursion and i dont know whether to try and find a 2 channel amp (but i dont know what amps can power two 1500W rms dual 2 ohm subs) or get a mono for each sub, if i pick option two I'd then have four amps in my car (ill have two for my components) im still pretty new to all this so i dont know if thatd be too much. if its okay to be running 4 amps then should i get a power distribution block for the four amps, what kind of wiring and how many fuses and grounds should i use?
Thank you for the help
Why not get a bigger mono, 3000 rms
kstark9392
kstark9392
Spring Grove, IL
kstark9392
