Need amp to push round q-series 12" 2 ohm dvc kickers
Bradbang
Ohio
I got my new kickers and they are 2 ohm dvc 850 rms. I ordered a soundstream reserve that was stable @1 ohm 1700 rms. I got the wrong amp. I want the 2 ohm subs, but i didnt realize the soundstream would fault out instantly at .5 ohm. I tried just running 1 2 ohm 12 in series to 1 ohm to said amp, and my kicker 400.1 cxa pushed it harder. I need help guys. Right now im looking at taramps smart bass 3k, theres a couple memphis amps 2000@4 ohms, same with nvx. I dont know about nvx tho. Im really leaning towrds the taramps cause its stabke at .5 ohm 3000 watts. Which way do i go? Should i go 4 ohms or .5 ohms? Or should i send the kickers back for the 4 ohm and run @1 ohm and shop for amp that way? My end goal is teeth chattering bass. I can sacrifice quality a tiny bit for the deep lows, and these kickers can take some abuse, but id still like to keep clipping to a low.
So no. Send the subs back and get D4 ohm subwoofers or get a 2 ohm version Taramps MD1800.
What is a 1500ah battery?
1500 ah is amp hours. Its recommended to have 2 ah per watt of power. And im not opposed to doing the big 3. I was just hoping to get by without having to redo the alternator. Zero gage wire is a must, and a battery is deep cycle battery is easy. Just really dont want to have to spend the money on a new high output alternator if its not necessary. I may just run it @4 ohms 1700w anyhow and get a good 5 farad cap.
Never seen a 1500ah battery in my life.
A 5 farad cap is just a waste of money. They are gimmicks. Super cap banks are a different story.
I just ran across this on YouTube. Bench test on a Down4Sound JP23 sub amp. Looks very impressive. The bass knob is really something else. There are volt/temp readings, there are power/protect/clip lights on it to go with the volume/gain button.
Went to the Down4Sound website and pics of a bench test showing it going to .5 ohms. And, bench tests show it surpassing specifications, separate from the YouTube video.
It looks to be a quality amp.
Maybe it's for you. Maybe not. Just had to let you know what I found.
You will need really good electrical to supply that amplifier for the demand.I myself would not run a daily vehicle @.5 ohm. Id run 1or 2 ohm for a daily on sub stage only lower if I were competing or doing Burps. You wouldnt want to Cook a fairly decent amplifier on Chitty electrical and Void a Warranty in a couple weeks if not days
Point well taken. I, too, would never run a daily vehicle at .5 ohms. I don't think I would run any sub at .5 ohms. But, I just saw that video on that Down4Sound amp and was impressed. In fact, I saw quite a few videos on Down4Sound amps and they all easily surpassed published power output specs.
I know nothing of Down4Sound. Don't know if they blow up after a month or a year. But, unlike a lot of amp manufacturers, their published power specifications seem to be very conservative. And, priced very competitively.
503
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
897
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Bradbang
Bradbang
Ohio
dsw1204
SlugButter
    May 4, 2024
slater
    May 2, 2024
