Need amp reccomendation for some JLW3v2 D4
you will need a mono amp that does 600 watts at 1 ohm , I believe the mtx does 600 at 2 ohms , so that would not be a good choice , the jl does 500 at 1.5 ohms , so that wouldnt be good either . try to find a jbl 600.1 that would be good or any other that does 600x1@1ohm .
OK, i'm confused. On JL's website, it shows that when the JLW3v2 D4 wired in Series/Parallel, they run at 4ohms.
Shouldn't I need an amp that runs 4ohms?, ..or where does the 1ohm come from??
two dvc 4ohm subs can either be wired for a 1 ohm or 4ohm load . wiring them to a 1 ohm load would be the better choice . check out the diamond audio d3600.1
Motley
Motley
Denver, CO
ighettoboyi
