Need Amp Ideas...
I'm looking to put an ALPINE SPR-17S 6.5" TYPE R 300 WATT COMPONENT SPEAKERS SYSTEM in my 95 Silverado. What I'm looking for is different amp ideas to power them.
Speaker SPecs:
2-110 watts RMS
330 watts peak power
External crossovers 12dB high pass and 6 dB low pass
87 dB sensitivity
Frequency response: 65 Hz - 27 kHz
Any help would be greatly appreciated. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would look for a 4 channel to bridge for those speakers. As lnog as you can get at least 110x2@4 ohm your good... its always nice to have headroom thogh.
The truck has 2 6" in the door and a spot for the tweeters in the door as well. The factory doesn't install the tweeters unless you opt for the sound upgrade. There is also a speaker in the pillar behind the seat. So I might upgrade later. I'm not trying to spend more than $150 on the amp. I'm told that that is not a lot for an amp but its what is feasible right now
Can I run the stock speakers with the new setup?
Do the tweeters have the same RMS rating as the woofers?
Can a tweeter and a woofer run off the same channel on the amp?
If so, do I need an amp with more than the rated 110 RMS/channel value?
SPR-17S Specs on Alpine USA
:rolleyes:NOOB:rolleyes:
BUMP
celinaman060
celinaman060
Up the street
celinaman060
vegang
vegang
