need amp ideas for 4 sundown audio sa-8 v2
skippy90210
Im going to be making a new system and im going to be using 4 sundown audio sa 8 v2's rated at 500w rms each what would be a good amp for these im willing to use one big one 2 or even 4 amps but i don't want to break the bank i was looKing at the kenwood kac-9105d thanks!
just did 4 of these on a saz3500 @.5 ..it loud to say the least..id look for a solid 3k if the saz is out of you.re budget
Just remember the 500rms is underated ..I was giving my sa 12's 800 watt daily ..sold to my nephew still giving them 800 watt ..still going 3 yrs strong
They was rated at 600 rms
well 1000 bucks for an amp is alot but considering i was gonna buy 4 of those kenwood amps at 200 a peice an extra 200 bucks would be worth it because that looks like one hell of an amp and what do you mean by @.5?? im new to everything in car audio
your not going to find a good enough 4 channel or 2 channel for the price. you dont need 4 mono-block amps for 4 subs. you can run 1 mono amp on all four, just have to wire it right. are you getting d4 or d2 subs?
i would agree to get a solid 3000rms amp. those subs take every bit of 1000 each, just feed them clean power
SA-8 V.2 D2 - Sundown Audio 8" Dual 2-Ohm SA V.2 Series Subwoofer
Fms: 70.6 Hz
Res: 48.4 Ohms
Re: 4.0 Ohms
Qms: 5.25
Qes: 0.75
Qts: 0.65
Rms: 6.9kg/s
Cms: 0.06 mm/N
Mms: 81.6 gr
Nref: 0.16%
Bl: 13.9
SPL: 84.0 dB
VAS: 3.5 L
Rp: 25.0 Ohms
Lp: 14.2 mH
Cp: 617.2 uF
Le: 1.00 mH
RMS Power: 500Watts
Enclosure reccomendations
Sealed: 0.28 ft^3
Ported: 0.5-0.75 ft^3 @ 35hz
Displacement: 0.08 ft^3
Depth: 6 5/8"
Outside Diameter: 8 3/8"
Cut-Out: 7 3/8"
theres most of the specs
if u havent bought the subs get 2ohm that way u can wire to 1 ohm at the amp
---------- Post added at 11:55 AM ---------- Previous post was at 11:55 AM ----------
yes get 4 2ohm subs
---------- Post added at 11:56 AM ---------- Previous post was at 11:55 AM ----------
ur also gona need some 1/0 wire a couple good agm batteries and probably a ho alt
so your saying not to buy those subs? if not what subs should i buy? i was looking to stay with the 4 8's idea
---------- Post added at 12:00 PM ---------- Previous post was at 11:59 AM ----------
ya all the wiring and that is no problem to me
We did 4 SA8's on a 3500 a few times..works pretty well. If you plan to run that much power though, you need to consider electrical upgrades to go along with it.
I would keep the 8's if that is what you want, but look around the classifieds for a used amp perhaps... You could look at the SoundQubed 2200 or 3500 both will do very well on those 8s.
skippy90210
skippy90210
ramey, PA
skippy90210
