Need advice.
Kursed
NY
Tsunami DB1800T Question for my sub
How is the amp for One 12" Re audio XXX. Would it be a good match or should i look for somthing else?
I bought a box off a friend for 10bucks made out of 3/4 MDF with a square port. was it worth 10bucks or not? cause its adjustable so i can always take out the port and cut it to be shorter or longer?
box specs are
H - 15 4/16"
W - 31 1/2"
D - 17"
Port
H - 5 4/16
W - 5 4'16
D - 11 1/2
if i remeber correctly that amp is 2 ohm stable so it would not match up well with the xxx being dual 2 ohm. (assuming that is the actual configuration) as for the box assuming it's well built i would say it's a good deal considering supplies to make would be over $10
Kursed
Kursed
NY
iceteebone
vegang
vegang
