OP
ol scratch
- Thread Starter
- #16
I like the specs on the tc sound epic 10". I don't like that it is only 2 ohm dvc. I would prefer 4x4. My amp is rated at 1 ohm but the bp600.1 have been none to shut off when running very long at 1 ohm. The tc epic is rated at 500 rms, my amp is underrated at 600 rms, closer to 750 rms at true 14.4 volts. If I go the tc epic route at 1 ohm, will it help prevent the amp from shutting off if I turn the gain down? I will have to anyways to prevent the amp from blowing the sub (theoretically anyways). But considering that newer subs are not so sensitive to being somewhat over powered as they used to be. I just don't want to burn up my amp, and at near $200, I don't want to blow the sub. So, will turning down the gain help prevent the amp from overheating and shutting off?
