need advice on this installation before i start
  • Thread starter wmdtib05
  • Replies 0
  • Views 463
wmdtib05
any advice before i start this installation? ill be using all my stock wiring and stock alternator 95 amp upfront until i get some help on the big 3 but for now i think i can handle all the rest plus ill be adding a battery in the rear close to my amps. my plan is to run 1/0 from the front battery with an inline fuse 200A direct to a kicker distribution block then do the same thing from the rear battery 1/0 inline fuse 200 amp fuse to the same distribution block then from the same block i add a very short 2or4 gauge to a twin fused block then from both my amps i'll add 4 gauge wire. im using jl audio 1000 watts that have a fuse rating of 100A and an alpine 545 with a fuse rating of 80A. so ill be adding two fuse in the twin fused block 100 and 60a just to protect the 4 gauge wire into the amps and on the grounding. ill ground both amps with 4 gauge to the chassis close as possible. rear battery: ill ground it the same way but ill use 1/0 any advice on this anybody?!?!?!?!?!
wmdtib05
wmdtib05
long beach
wmdtib05
