Need advice: Bit10d or DQ61
gn_rx7
I am having one of these two options installed to finish my first SQ setup this week and would appreciate any advice. This will be added to a system with components up front and 2-10's in a sealed box in the back.
The DQ61 is marginally cheaper, but not enough to sway my vote if the Bit10d is that much better.
My biggest concern is whether either of these have any issues when integrating with a stock bose system without affecting the Bluetooth, navigation or safety warning features of the stock system.
Other than any potential integrations issues, my gut tells me the DQ would be sufficient, but the Bit10d could be a worthwhile step up since it includes cross overs and has a better EQ and TA features. I have heard a car with the Bit One and it sounded great, but was more than I want to spend so I think the Bit 10d would be the best option since it shares most of the same features, but wanted to double check before I drop the cash.
Thanks
Are you having a shop sell you the parts and install and tune the system? Price should not really be a factor here as these two devices are not equals. Retaining your factory BT and notification sounds is not an issue with a competent installation that pulls signal from the right places.
Yes, everything will be purchased, installed and tuned by an authorized dealer.
Thanks for your comment and confirming my impression of the products! I don't mind spending the extra for the bit, but wanted to confirm that it wouldn't be an unnecessary waste of money.
One other question.
How important is an RTA for the tuning process? I'm not trying to compete or play at maximum volumes and will have plenty of headroom, so the gains will be set low and clipping will not be an issue for really loud volumes. My plan was to start of with a flat tune for one setting and then make some minor tweaks to reinforce some midbass frequencies and vocals based on my ears for the second setting. Honestly, all I care about is what my ears tell me anyway as long as I'm not damaging the speakers.
The reason I am is I'm trying to close between two shops. One is a high end shop that I know has been in business for decades and I have personal recommendations for. The other is a shop that has an RTA, but I do not know anyone that has experience with them.
Perfect, I was hoping the RTA was not necessary because I would prefer to use the shop that I am familiar with. Plus, they are supposed to be getting the bit tune in a few weeks for a follow up tune once the speakers are broken in.
Thanks
gn_rx7
gn_rx7
Houston
gn_rx7
