need a strong 4 channel
itsblown
why is there smoke?
Well not really that strong but looking for something to power some morel maximo 6.5's upfront and a pair of maximo 5 1/4's in the back.
Was strong considering the dd c5c but I would have to drive about 2 hours away to the nearest dealer anywhere I can pick it up online or some way easier? and any other amps out there that can put out as much power as the c5c for 250? here are its specs.
Bridged 280 x 2
Channels 4
Cont Power at 1 Ohm NA
Cont Power at 2 Ohm 140 x 4
Cont Power at 4 Ohm 100 x 4
Damping Factor >100
Dimensions (Inches) 2.08 x 9.45 x 15.75
Dimensions (Metric) 53 x 240 x 400
Dynamic Power 800 W
Efficiency Thru Output NA
Input Sensitivity 0.2 - 6V
Shipping Weight 11 lbs
S/N Ratio >95dB
Tested THD 0.05%
Tested Voltage 13.8V
Variable Bass Boost 0 - 12dB @45Hz
Variable High Pass Filter 80Hz - 5kHz @12dB/oct
Variable Low Pass Filter 50Hz - 500 Hz @12dB/oct
Would it be cheaper to get 2 different monoblocks perhaps? im guesing no lol let me know your suggestions
Now im thinking about the crescendo 1100.1 any ideas?
---------- Post added at 07:40 AM ---------- Previous post was at 07:40 AM ----------
Also planning on running front stage active
What's your budget?There is no such thing as a highend 180x4 amp for 450 bucks..
I never said High end bro...
Now just looking for a strong 4 channel to go active on the front stage now
---------- Post added at 07:47 AM ---------- Previous post was at 07:47 AM ----------
Tested close to 200 x4...
May hit you up on that I will let you know
Not you but some peeps here seem to think one company Is better than another and they use the same of nearly the same parts..
Chinas amps aren't as good yet they don't have a clue that 99% of parts come from china and china actually makes the best transistors..
Anyways..
Without knowing your budget..
The crescendo or sound stream reference will do fine, if you want to spend allure more
Audison, dd, zapco, and zed are highend amps..
Anyways..
My front stage amps are Chinesse. I would say they are pretty **** good
itsblown
why is there smoke?
itsblown
Toledo OH
Papermaker85
