OS Amp decsion, Eclipse XA4000 or MMATS SQ-4070
ace_800
Both the same price shipped. MMATS has all plugs
Eclipse
4-channel car amplifier
ICEpower full-range Class-D amplifier design
Fuse rating: 30A x 3
Dimensions: 15-3/4"W x 2-5/16"H x 10-1/4"D
Power:
125 watts RMS x 4 at 4 ohms
175 watts RMS x 4 at 2 ohms
350 watts RMS x 2 bridged output at 4 ohms
Specs:
Variable high-pass filter (30-500 Hz, 18 dB/octave)
Variable low-pass filter (50-500 Hz, 18 dB/octave)
Variable bass boost (0-8 dB at 32-64 Hz)
Subsonic filter (18 Hz, 18 dB/octave)
MMATS
Amplifier Type: Dual Channel
Bass Boost: With Bass Boost
Bridgable: Bridgable
Power Output
RMS Power at 4 Ohms: 70 W x 4(Underrated I hear, not sure how much though)
Performance
Bass Boost Frequency: 45 Hz
THD at Rated RMS Power: 0.05 %
Signal to Noise Ratio: 105 dB
Frequency Response: 10 Hz - 25000000 Hz
Other Features
MOSFET amp: Yes
meh, leaning more towards the eclipse. The plugs on both sides of the amp kind of messes up where I am going to mount it. Plus its a stronger amp with better xovers.
The mmats is by far superior..
Care to explain in detail?
Here's some inside shots:
Yeah man you definitely should've picked up the MMats lol...It's way more efficient and it's more than likely a better SQ amp as well. Not that the Eclipse is bad, by any means.
lol more efficient? you have any tests showing the mmats efficiency?
and i doubt it's sq is better.
cuz a watt is a watt 'member? //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
Mmats amps are superior, I'm not going to get into an argument..
Look up the parts and do the research..
If you where comparing mmats to zapco etc then it might be legit but your comparing it to a ice powered full range class d amp, the slew rate alone will tell the story..
ace_800
ace_800
Okinawa, Japan
destined2race
