Need a single sealed box design/plan/cutsheet
For Rockford Fosgate Punch HX2 RFD2212
I have attached the PDF manual for the specs
If anyone can help I would greatly appreciate it.
thanks
Dan
For a sealed box just determine the max space you have to fit the box, and adjust from there using this formula:
L x W x H (all in inches) = cubic inches. Divide that by 1,728 to convert it to cubic feet.
Adjust the dimensions until you get the volume you want/ need.
ok so 14" x 14" x 14" = 2744 divided by 1728 = 1.58 Cu Ft ?
You got it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't forget to take into account the displacement of the other items in the enclosure that detract from the gross volume.
huh? lol so if i use 3/4 MDF i have to count for that? now i'm confused.
Things like drivers and braces will subtract from your initial volume leaving you with a net volume that may be less than your target volume. You should be using inside dimensions for figuring volume so you don't need to account for the material thickness unless it's an internal brace.
Don't forget, if your BOX's dimensions are 14" X 14" X 14", then the INTERNAL dimensions are actually 12.5x12.5x12.5 because of the 1.5" you have to subtract the width of the two pieces of MDF from each dimension.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To be clear ... A 14" x 14" x 14" box made from 3/4" think MDF measures only 12.5" x 12.5" x 12.5" on the inside. So, while the outside volume of the box is 2,744 cu in (1.58 cu ft), the inside volume is only 1,953 cu in (1.13 cu ft)
From that #, then subtract out all other solid object(s) that will be in the box, including the sub itself, and any internal braces. The same MDF makes for good internal bracing. The # you're left with is your net volume. You need to adjust the box's overall dimensions until you get the correct net volume you need.
xDATx
xDATx
Los Angeles, CA
supermaxx123
