need a fart box design
MemphisCherokee
analrapist
looking for a design
for 2 memphis PR12's
max dimentions: 20 deep, 18 tall, 40 wide
t/s:
fs:32hz
vas:2.16 cf
mms:136 grams
xmech:.352 in
qms:5.37
qes:.42
qts:.39
sensitivity:88 dB
coil diameter:2 in
Bl:15.41
coil config: single 4
2 drivers
250w each
im looking for purely SPL
total fart box
around 50 Hz or whatever will get me the most output
honestly, i'd rather not pay for the design, im broke enough as it is
i would usualy do it my self but i dont have the time right now and ive never built a purely spl box
all i really need is airspace, port area/length, and orientation
put paypal ready in your title and u'll have more than enough ppl wanting to help //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Do a CRX style box...subs up port back.....put each sub in a 1.5 cu ft chamber counting port and basket displacement...use 2 5" ports per chamber...PVC or aeros even better if broke make your own....make each port length about....16" long.....You should be set....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Try to fit the box so the port is about 7" from the rear hatch ....Have subs firing up as close to the rear seat as possible......The box will probally be sorta shallow...make sure you have at least 2" below the magnet so the subs can breath...If you share chamber....with subs...I would...put the ports fairly close to each other side by side ...and have them opposite of where your vehicle meters best from.....For instance...you meter best on passenger side...have the two ports on the drivers side of the box towards the rear.....Hope this helps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
MemphisCherokee
analrapist
MemphisCherokee
Davenport, IA
MemphisCherokee
