i have two E8s coming and im trying to build a ported enclosure for them. im trying to use a precision port from my last box for the port on this new box.
the port is exactly 15" from flared end to flared end and its already glued together with pvc glue so it would be kinda hard to cut this thing to another length.
so does anyobdy wanna try and build a box, 1.2 cubes single chamber, incorporating the single port listed above that can fit two sundown E8's?
heres some specs taken directly from woofer cookers thread
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
if somebody thinks they could make it work that'd be great. i could probably throw you a few dollars via paypal
subs up/ suns back/ ports firing to the side or front. doesnt really matter. dimensions arent really a problem either as the box is in the back of my jeep so theres plenty of room. im used to having at least 6 cubes back there soo...
Ported Box:
F3 of 25 Hz
Depth = 4.25"
Cut Out = 7"
