need a comp. sys. under $200
do the hertz have quick response. i listen to alot of trance and drum n bass and when the drum n bass is pounding, it starts to drown out my mids and highs so i want sumden that can keep up and wont drown out or distort
I think the Hertz will perform well, but I would go listen to them first to make sure. Me personnel, would not buy any gear without listening to it first.
only if it were that easy. most places dont have those top of the line brands. they have all the common brand names
199
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
151
505
slconde
slconde
houston, tx
slconde
    May 20, 2024
    May 20, 2024
