Need a box designer for street beater
937DYTBOI
TL>you
I need a box design for my new box im trying to build. My dimensions are 34"wide, 14" tall, 24" depth. I want four 4" aeroports which will be 17" long on the right side of the box. The aeroports are the ones from parts express, if 17" is mangageble in this box or whatevers best. I really want the box tuned around 30-32hz so i can hit the lower notes, jus want the box box for a everyday streeet beater. If someone can come up with the plans for me i would appreciate it.
Subs are the ones in my sig
Rear fire subs5.2 cubes(gross)
(2)front&back 34"x14"
(2) sides 22.5"x12.5"
(2)bottom&top 32.5"x22.5"
all ports in square format on right side meaning 2 and 2
23.5" long
Will that work?
So the port is to be 23.5" long, so i cant do the 17" long aeroports
You can just use PVC to make the port tubes the length you need.
Thats a bet, hopefully i can get started on this soon, when i get some spare monies together. i like thos flares though, oh well its the performance that counts. I appreciate the help though thanks
Get the flared ports.... but only use the ends.... just use PVC for the connecting tube....
(I wasn't sure if you got that)
Bet on homie i will come to u if i have any problems. this box will be quite simple jus help wit the ports and supporting them. So let me get this right each port should be about 4 and sum change length wise
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
937DYTBOI
