NEED 8000 WRMS amp(s)!!!!
I don't really appreciate the sarcasm.... I understand I don't know everything there is to know about car audio, but no one knows everything. . . I havent had an install with this much power so I don't know what to expect . . . Exactly the reason I am here right now asking questions. If anything I am pretty smart for asking questions before i try to install it all that way I don't ruin anything. . .
How many more batteries do honestly think will be necessary ? Ill have that 260 amp alt and I guess i can squeeze more money to get 4 2400's rather than 2... is 4 not enough?
The rule of thumb is 100ah for every 1000w.... The 2400s are rated at 124ah. So definitely look into at least 6 of them. Especially if your going to be running each amp at .5, you WILL need the extra batteries...
Thank you !!! Good info. lol. I will keep this in mind when Im getting everything together.
id grab that stetsom7k or the 11k if you want to spend the money. Crazy effecient amps. I think the 7k retails for like 4g's or something. I know the new 14k is like 9gs
I have been looking around and I think Im gonna snag a Stetsom 7k 12v model.... Apparently they do about 7000 at 13 volts... which is amazing... I could be getting about 9000 rms at 14.6 volts then...
After rise you may get 7k @ 14.6 on music, but thats in a perfect world. With any V drop your looking @ 5-6k rms.
May wanna look into an 200 amp alt w ext regulator if you really wanna keep that V high, along with atleast 500AH in batts
Im installing a 260 amp iraggi alt.... and probably 700AH in batteries. . . . So should be able to get that 7k then ?
Treo Engineering CXT6.1i
900Wx1 @ 4 Ohms 0.1% THD 14.4VDC
Accepts input voltage up to 18VDC
no idea on a price but it is .5 ohm stable and well underrated, this would pose a challenge to your XXXs especially at 18V
rickymac21
2loud4u
rickymac21
washington,OH
Matt A
