narrowing it down your thoughts?
magnumsrt8215
im narrowing down my options so here is what i have in mind for a new sub amp. New to the list is digital design m1c, jl 1000v2, sundown saz 1500d, rockford t1000, and alpine pdx1000. im looking for a clean and powerful. my subs are (2)10w7's they will be sealed. I need at least a 1000 watts. suggestions?
No you don't. A 500/1 will beat those up quite nicely. Upgrading to its big brother, the 1000/1, will have little perceivable difference. JL changed their power rating recently and I think they did the same with the box requirements. A slightly larger sealed box usually sounds better on JL woofers regardless of the model. Just take it easy with the power; these subs don't need a lot to get moving.
I think the sundown and DD might be too much for the subs. JL doesn't really under-rate their stuff. RF is typically pretty clean. And BnG makes a good point up there, you really wouldn't notice much of a difference. I'd take the cheapest of the JL, Alpine, or RF.
I just don't want to not hav enough juice. I didn't think 250 per sub would be enough that's why I said at least 1000. Once I buy that's it I'm not gonna be able to upgrade without losing the money I put out.
the dd is your best bet. your running at 1.5ohms and it's rated at 1200 at 1ohm so 800-900 give or take.
it's also smaller and much more resilient to voltage drop then the sundown is
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
701
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
magnumsrt8215
magnumsrt8215
Philadelphia Pa
wenn_du_weinst
    May 18, 2024
    May 18, 2024
