n00b - best 8" sub?
reverse mount would defeat purpose of a stealthsub
What kinda car is that?
IDv3 may be right up your alley then
what is the airspace in the box. maybe some assassins
soundsplinter RL-i8 little 18lbs monster. deff will sound good 500wrms
Soundsplinter RLi Ascendant Audio Assassins
Image Dynamics IDv3
all 3 no go...too deep. the depth is 11cm which is about 4.25in...RLi is 15cm deep while assassins and id is about 4.75in so none will work
jl w7. period best sub ever created.
like others mentioned, it is too deep and won't fit
On the ID you can remove he plastic cover, should then fit.
you could try an 8 inch kickwoofer from ground zero or use the kicker and put a passive radiator next to it or make the dang hole bigger and call it a 10" but trying to be stealth
(it put on weight over the summer) there is also the likes of a fusion 8" ive heard good things never heard it but well there you go
unknown00
unknown00
TX
unknown00
