envengineer
I agree for the most part.How can you go active if your only using 2 channels for the front stage? You can not bridge your 4 channel amp, 2 of those channels have to go to your tweetes, then the other 2 to your midbase/range.
Xover the tweets HP around 4000hz-5000hz and LP the midrange from the tweeer frequency and HP it around 80hz. The subs can have 80hz and down.
Just forget about rearfill, and changing out your 12's for 10's for SQ is crap, your setup now is fine.
When you set the crossovers for the mid/tweet transition, it's probably a good idea to leave a gap since the crossovers points are not brick walls, but slopes. You have to look at the individual drivers to know where the crossover points should be. I cross my tweeters around 2.4khz and my mids are crossed around 1.8 khz down to my midbass at 200 hz.
The "forget about rearfill" comment is correct. You don't need it. It's obviously up to you, but I hate the way it pulls back the stage that I work so hard to move forward.
Don't push that DIYMA too hard if it is going to be in a very small box. They are not designed for high output (even though they are capable). The motor has been shown to be a little too strong for the cone when placed in small enclosures that result in the cone buckling or tearing due to high pressure. Just be smart with the DIYMA and it will perform very very well.
