my system
  • 4
lehto-mike
what do you guys think of this system?
Pioneer TS-W257D2- 2 of these.
Kenwood KDC-MP338-head unit.
Kenwood KAC-7204
THIS JUST TO POWER THE TWO SUBS.
Technical Specification
RMS Power Range : 170-500 Watts
Number Of Channels: 2
Maximum Power: 1000 Watts
Low Frequency response: 20 Hz
High Frequency Response: 20000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
2-Channel car amplifier
RMS Power @ 4 Ohms: 170 watts x 2
RMS Power @ 2 Ohms: 250 watts x 2
RMS Power bridged @ 4 ohms: 500 watts x 1
CEA-2006 compliant
High-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
Variable bass boost (0-18 dB at 40 Hz)
Aluminum Die Cast Heat Sink
Cooling fan
Power MOS-FET Switching Power Supply
Speaker-level inputs with signal sensing turn-on
Gold Plated Power & Speaker Terminal
Signal Sening Turn-On
Preamp-level inputs and outputs
Just an FYI to the OP: The build logs section of the forum is for builds that are finished/under construction, and usually people like to see pictures of the builds.. that's kind of the whole point of this section. This isn't really the right place to just see what people think of your potential setup.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
185
606
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
lehto-mike
lehto-mike
dudley,ma
Punk In Drublic
    May 31, 2024
    May 24, 2024
