My system isn't working anymore?
Here are pictures of my fuse boxes from the owners manual. Could someone help me out by telling me which one of these correlates to the power of my amp and subs? My head unit is fine. Honestly I don't understand how this has anything to do with it, because I'm getting power to my amp through the power wire, I checked that and it came up as good (unless I did it wrong [first time using a multimeter]) but here it is.
Under hood fuse box
Glove box fuse box
I've more pictures if you need any more information.
I have a regular old analog multimeter, would that suffice? I'm new to all of this stuff including electronics. I checked my remote wire by switching the multimeter to what looked like the symbol for ohms and measured it at x1k and it said it was good. Then I checked my power wire, it didn't register at x1k so I switched it to x10 and it read positive as well. Did I do this correctly? How would I measure whether or not the fuse is good? What setting do I dial it to? Sorry for all the questions I'm just lost and frustrated right now.
EDIT: Also do you know what the fuse I would be looking for is called? aux input fuse?
Take your dmm and open your hood with your car radio on. Check the voltage at your battery terminals and then go all the way back to your amp and check the voltage off your ground and power wire in the amp. If the car is off, it should read along the lines of 12 volts. They should both match up . Also check the voltage of your remote wire as well. Just touch the dmms positive wire on the remote wire and get the negative wire and just ground it somewhere and see what that reads.
also, switch the dmm to volts
Do you have an INLINE fuse from the wire you ran from the battery to the amp?
If you're talking about this,
then yes. It's hooked up properly as well.
---------- Post added at 10:33 PM ---------- Previous post was at 10:32 PM ----------
Alright, I'll try to do what you just said. I don't know if it be accomplished with this cheap analog multi meter because the choices for volts go from 10, 50, 250,300 max. I wish I had bought the digital reader instead //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif.
Analog is fine if unit works. fractions of a volt shouldn't be necessary. I'd check the the fuses under the hood too. If you want to know what they go to, pull them and try to turn stuff on. I don't know if this can hurt your stuff... but I've done it plenty albeit without much to lose. Just leave the relays alone.
I'm fed up with this bullshi t. I can't figure it out. Everything has been checked with the multimeter and has power, I've checked all the wires, checked the fuses, and now I've exhausted all of my resources. I've been working on it for 5 days straight in my free time and nothing has come of it. Time to take it to roberts audio or best buy.
Xander... try this remove everything out of the car... amps , radio , wire that you installed... start over from step 1.
running all wiring (without hooking it up)
hookup the radio
hookup the ground wires making sure everything is clean and secured tightly
hookup all the rca's and other speaker wires
hookup the powerwire from the battery to the amp with the fuse removed
hookup the remote amp wire
make sure everything is completely tight and secured.
put the fuse in and check it then... sometimes its easier and faster to start over and go slowly than to work backwards. If this doesn't work then i would take it to someone else.
xander37
xander37
louisville, ky
mylows10
vegang
vegang
