my system doesnt power up! help please!
BJ The Man
Today i went to my car, turned it on, and found that my HU or my amps would trun on with the ignition. There was no way i could get my system to turn on. So i searched behind the HU and saw everything connected and the remote line too (i made sure to check that since the amp wasnt going on). i then checked all the wiring throughout the car and its all connected correctly. No broken wires or anything.
to test to make sure the HU wasnt skrewed up i put my stock one in. I could get it to tell me the time and load CD's but i wouldnt play the cds. Then i put the pioneer HU back in and it wouldnt even power up and neither would the amp.
I seriously need some fast responses cause i dont know how long i can go musicless in my car.//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/pissed.gif.9f665f96bc89e98e708dabd4580bb591.gif//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
hmm... not sure what to tell you if you checked all the wiring and fuses. i had the same problem not so long ago and it was because i had a blown radio fuse in my car's fuse box.
I'm actually having the same problem with my system right now. My head unit comes on but my amps don't turn on. I was going to pull my H/U out today and check the remote wire. Still need to check the fuses.
Well, it turned out to be a fuse. Only this fuse wasnt near the battery or the amp or HU it was like the master fuse area of the car. I had to read my cars manuel to find it. I then replaced the fuse and everything worked again..finaly..whew
BJ The Man
BJ The Man
Traverse City, Michigan
ahboy
