my switch
lebaron87
i have my amp on a toggle switch. if the power source to the toggle switch is a good connection to the fuse will it stop my amp from putting out alot of watts. it still worked but i checked the connection and made it better and it sounded like it harder
Lebaron
do i understand you to mean that you have the power connection going to the battery via a switch?? thats not good because every 240 watts draws 20 amps of current, and most switches can handle 10amps at the most, you might start a fire, its better if you connect the remote wire via a switch because the remote wire is around 0.5 amps, it always stays the same and you can use a tiny micro switch for that.
Originally posted by lamontjersey do i understand you to mean that you have the power connection going to the battery via a switch?? thats not good because every 240 watts draws 20 amps of current, and most switches can handle 10amps at the most, you might start a fire, its better if you connect the remote wire via a switch because the remote wire is around 0.5 amps, it always stays the same and you can use a tiny micro switch for that.
I agree he is right //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
no not the power wire for my amp. the system control wire off the amp is going to the switch and the power for the switch is from my fuse box and the switch is grounded to metal on my car
lebaron87
lebaron87
newburgh,NY
lebaron87
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
