My setup just shut off.
sudrummerboy
B4 yall start, I checked all the fuses, connections, wires, I even checked the temperature //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif !!!
The only thing I didn't check was the amp fuse b/c I couln't pull it out, and I don't have a volt meter.
Anyways, I was driving an i noticed that my subs weren't hitting. Was it my amp, blown fuse, bad Install? If it's not the amp fuse, then what could it be?
maybe u finally went deaf //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
probably the fuse, that is my guess. i have ran into some weird things like amps just dying, but out of all the amps i had, that isnt too regular. check your power connections, including where you have it grounded, and check the fuse. those are your best bets.
how do I remove the amp fuse on the BX1000d?
i think it might be because of the way he wired the amp to the box:
He has each terminal wired to each channel, and thats not how I want it.
yeah I did, It's ok it hink it's just the amp fuse, but i don't know how to remove it to check it.
See attached (I'm pretty sure thats it) unplug your front fuse or pull the positive off the battery when you yank it out to be 110% safe. If it have char marks or the metal inside it is broken anywhere, you need a new one.
sudrummerboy
sudrummerboy
Atlanta, Ga
Zerstorer
