My setup and a few questions.
SQllover
Head unit:Clarion DXZ865MP
Equalizer:Eqs 6 channel
Crossover:6xs
Mids:Cdt Mi6s given 150 rms each
Tweets:four 1" silk domes, not sure where I'm gonna position them,ran off 4 channel amp at 60 rms each
Rear fill: Focal 165 6x9 and soundstream 3.5s ran off 60 watt rms 4 channel to replace stocks
Subwoofer:solo x 18 ran off memphis mojo 4kw, thining of taking out the center of my rear seat and lining the sub up with the hole in a 6 cube box tuned to 35 hz.
My question is what kind of electrical upgrades do I need ? I've yet to get all the wiring so it be cool to know what I'm gonna need for that to. I will probably apply sound deadener after wiring and electrical upgrades are complete. I hope I can hit a 150. This is my first system. I'm thinking of having it proffesionally installed. Any help is greatly apprciated.
Solo X and ur an SQ lover. It doesnt match, lol. I dont think u need the rear fill because ur front stage seems to be running alot of power and should sound pretty good. But then again its install dependent.
As for electrical upgrades u will def. need to do the big 3 (use the search button). It seems your stock Alternator only puts out 70amps max, which isn't that good. It seems the Memphis Mojo MCD4KW comes with 2 250amp fuses which they say you must use. So you def. Need a High output alternator, Battery upgrade (maybe even extra batterys in the trunk) and many runs of 0AWG wire. Before you do this whole thing make sure you know what your getting yourself into.
I only ever seen one in competition, I think he competed anyway. Worked for alpine and had three 12"s in the trunk. These cars are hard to get loud ? Is it because of the size of the cabin or the resonance frequency? I had no idea.
Well if I remeber right the backseat doesnt fold down. I see what your deciding to do with taking out the middle of the back and having the port firing into the cabin. But getting 150 is pretty hard for a trunk car anyways. If ur plannin on doing just test tones and competeing your gonna need to tune rather high (40hz area) which isnt great for daily listening anyways.
SQllover
SQllover
canada
phyphoestilic
NorthFramingham
    Jun 30, 2026
