My project delay again
I had 8 tweeter enclosures made previously when the plan was to make a hybrid
line array and there was drama in making those, short story, the machinist
messed up a little, then I changed my mind on plating and the platers messed up.
What I got was 8 tweeter enclosures that were unique but not what I visioned.
It's ok, it's a consistent screw up and nobody will know. Here is picks of that.
Pics of machined parts; These parts is for one tweeter. I need parts
to make 21 tweeters plus spares, lots of work on machining. I'm not
a machinist so I have to hire someone cheap.
http://home.pacbell.net/lordpk/sa/4.jpg
Pics of tweeter;
http://home.pacbell.net/lordpk/sa/1.jpg
http://home.pacbell.net/lordpk/sa/2.jpg
Pics of tweeter inside it's own enclosure;
http://home.pacbell.net/lordpk/sa/5.jpg
http://home.pacbell.net/lordpk/sa/6.jpg
Pic of tweeter compared to an 8" midrange;
http://home.pacbell.net/lordpk/sa/7.jpg
Pic of a '4 stack tweeter' vs. Dayton PT2/NSB line array.
http://home.pacbell.net/lordpk/sa/test.jpg
Problem is, when the design migrated from a hybrid array using 4 tweeters
per tower to a full blown line array with 8 tweeters per tower, I need more
tweeters and enclosures. It would be difficult to duplicate the screw up
on those 8 tweeter enclosures so I figure I need to do a new batch from
scratch. I just have to find a machinist that wouldn't charge me a ton of money
to make 231 machined parts plus spares.
The tweeter enclosure is to protect the expensive tweeter, make it easy to
install in the box when arrayed, and you have to rework the internal
electrical wiring from the front of the tweeter to the rear of the box.
Yeah, that tweeter is a mechanical headache, but SQL is unreal and
worth the nightmare if you ever experience one.
There is a reason for my madness //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
They are magnetic planars, some call them isodynamic planars, the manufacturer
calls them 'ribbons' using the term loosely and incorrect, they are not true ribbons
like Ravens, etc.
This particular design offers the best SQ with SPL of all tweeters I've worked with.
There are two other brands in the same league but not available for purchase
seperately unless you want to buy the 'system' and remove the tweeters... lol
Only compresson drivers with horns can produce more SPL but SQ suffers
compare to this tweeter. If you can tolerate a we bit less SPL than a big
horn to gain a huge boost in SQ, this is the tweeter to get.
Tube geeks would get a boner if they knew it was 13 ohms nominal {high
impedance, tube amp friendly}, and 103dB sensitivity. They also sell a waveguide
for it to boost sensitivity to 107dB but the frequency response is peaky at some
mid frequencies.
If you have a wild imagination, imagine 21 tweeters in a 7.1 HT system where
the mains are 8 tweeter per tower line arrays with 8" mids and another set
of line arrays where you have eight 15" midbass drivers tuned to 35hz,
then add a monster high xmax sub(s), everything powered by over ten pro audio amps
in bridge mode for ultimate death and punishment.
They are magnetic planars, some call them isodynamic planars, the manufacturercalls them 'ribbons' using the term loosely and incorrect, they are not true ribbons
like Ravens, etc.
mid frequencies.
all I can say is, good lord!, that's some MAJOR gear.
:yumyum:Tweeters with SPL....
What he didn't say is that two of those amps are Crest 10001's //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
Bad news.
The machinist doesn't want to use the 3/8" material and machine it down to 1/4"
nor will the material vendor take the 3/8" aluminum and offer a discount on 1/4".
6 weeks later, I get a quote for the project.
$925 materials
$10,000 labor
Ridiculous.
This is his way of saying "I don't want to do this project" by giving a quote
that high.
We will get another quote from another shop for reference.
Boooo.....................
thylantyr
thylantyr
[Yoda] Belong to us all your base are...
thylantyr
