My Pg Rsd65cs Review:
I would guess that's because you have your RSd's crossed at 63Hz/12db, that they are "helping" your subwoofer, because they will be playing a lot of bass, too.
i had the fronts crossed at the same point before. i'm not sure what the reason is.
hey im about to buy these for my 1991 honda civic hatchback but i can't find the depth of these phoenix gold rsd 6.5" components. do you guys know the depth of these speakers? thanks for the help.
my civic has i think max 2.25"depth. i was thinking of using a kenwood excelon amp that does 180wrms x 2. but maybe i can make a 1" ring or something to fit the woofer.
well since i have had some time on them i have played with some settings on my head unit and they seem to sound even better now. i played with the EQ a lil more and also messed with the time alignment a bit. i now have 50hz at +1, 80hz at +2, 125hz at +1, 315hz at -1, and also have 8khz and 12khz at +1. so the EQ is still pretty flat for the most part but i messed with it a lil.
i also took a few inches off the right side on the time alignment, which brought the stage a little more to the left. BTW time alignment is sweet, you can actually hear the vocals moving around when playing with the settings. i never really played with it before, (i just set it and thats it) and i was shocked at how nice it works.
so after a couple days with them i still love them and they keep sounding better and better as time goes on and as i continue to tweak things a bit.
use 3/4 mdf to make a baffle/spacer for them as long as you can do that and still get the door skin back on.
yeah i'll try that a baffle or spacer and make sure i have enough space for the woofer to flex. thanks for the help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tcguy85
tcguy85
Hyde Park, NY
eggyhustles
ThxOne
    May 13, 2026
