my own sub
I pretty much know what I want
die cast aluminum basket
3' copper clad aluminum dual 1ohm voice on kapton former
quad stacked 400 oz motor with a 1' inch top plate for high excursion
I also wanted to try brake venting in the bottom plate like u see on high end car brakes
now what I need help with is finding the right soft parts I no I'm going paper cone all day with a poly cap
and if not China would Japan be better input peoples I'm here to listen
so basically its what I like about a lot of subs combined into one
thx for your input people
OP, if you're trying to break into the industry, not the way to do it... You need to learn some more before you can just "order some subs from china", cuz there is a hell of alot more to it than that. I would start by building your own sub, from different parts... just play around with some, figure out which motors, spiders, coils, cones, baskets, leads, etc that you like, and in which configuration... that is a good starting point... from there, you may be able to start planning. But, just to have "your own sub" and not try to profit off of it, i think you'll realize that it's going to be worth the MASSIVE headache it will create.
your right that's why I just want one prototype I'm not scared of failure I already own my own business
I pretty much know what I want die cast aluminum basket
I don't know where to start...
You say you own/run a business?
globalminds_ent
globalminds_ent
oxford ms
ciaonzo
