My own desiqn?
  • 5
Sugary Monkey
I used the instructions in the sticky to design this box using Win ISD
Sides 11.5X15
Top/Bottom 11.5X24
Back 13.5X24
Front 13.5X22
Port Area 14in2
Port Height 7in
Port Width 2in
Port Length 10in
Gross Volume 1.86 Cu ft
Net Volume 1.75
Tuned to 40hz
Please let me know if I've made any mistakes.
Make it 15" x 30" x 11 1/4" with 2 4" round ports 20 1/2" long. That will be roughly 1.75 @ 40hz with 25 inches of port. That port disturbs me. If you use a aero port you could get by with one port......make it 15 x 30 x 10 with 1 4" aero port 9" long that has 12.5 inches of port.
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
Sugary Monkey
Sugary Monkey
Owensboro KY
Sugary Monkey
    May 20, 2024
    May 20, 2024
