My New JBL Subs
JoseMCeee
$tack
UPS Guy "Wtf is this? A Keg?"
"Na there just some subs"
"Are they 15s?"
"Na just 10s"
"Oh I gess they are in a box already..."
"The cardboard one I gess..."
How do these work? I think they are for mounting the sub...
thnx. I think for those metal things Im supposed to drill a hole and probably add some silicone. Then the spikey parts are supposed to be hammered down. Ima go do that right now.
indeed are. pre-drill a hole to fit the t-nut. place the t-nuts on the back side of your baffle. insert the screw from the frontside and tighten. the force from tightning the screw will cause the t-nut to insert into place. remove the screw and intall your sub.
be sure to install them on the backside.
I have two of the 12" version of that sub except I have the dvc version. I like them a lot. Mine are in a 2.25 cu. ft. box ported at 28 hz each ( I like sq //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif ). I think you will enjoy them a lot. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They are in a dual chamber sealed box with ~~ .90 cuft each. Lightly stuffed with polyfill. I barely installed them today on my lunch break and the gain is 1/4 up. Havent really played with it yet. Sound good so far tho. I might have to give them time tho they are pretty Beefy. They look strong so it might take some time be4 i can really get the gains up.
JoseMCeee
$tack
JoseMCeee
Bay Area, CA
JoseMCeee
michigan born
    May 14, 2026
michigan born
    May 14, 2026
