BacksideUSA
Yesterday i added a set of rainbow comps, and a jl 360 amp to my system. (I also have a kicker 750 amp powering my subs) After i hooked everything up, i went to reconnect the negative battery terminal, and it went POP and blew my fuse. i replaced the fuse with a spare, and it just did it again.
i have a distribution block with 2 inputs and 4 outputs. i am running 4 gauge power and ground wires to each input, and then running 4 gauge power and ground wires from each output, to their respective amp. i've triple checked all my connections, and they're all legit.
Should i be running thicker gauge leads? Is it ok to run power and ground wires out of one distribution block?
