My friends phone play alot better through aux
  • 4
Warlevik
Sweden
I let my friend have the aux, and discovered her phone produces alot more sound than mine. Her 50% max sounds like my 100%. I find it weird because we both have the exact same settings on spotify and same brand of phone. I have the iphone 11 pro and she has an iphone 8, so if anything id think mine should sound better as its newer but no. Anyone got any ideas to why this is?
Yes I’ve checked and every restrictive setting is turned off.
Have you compared both phones using headphones? I used wired headphones to the point of weakening the prongs in the port, causing sound issues and at times not holding the pin in place. One solution would be to use a BT dongle. I use one in my HT setup and only drawback is the loud "low battery" chime in the middle of a good show.
Different phone models have different output voltages. Older iphones and android phones used to have slightly higher voltages (.8-1v) but the new phones aren't as high (.5-.8v). Phone arena used to measure the aux out voltage but now that everything is wireless and bluetooth they stopped measuring that data point and only report db from the speaker.
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
I got my microwave hooked up to my stereo...the bass drop when my hot pocket is done is quite frankly breathtaking...
It all works fine, I had to change the Bluetooth connection type on my iPhone from being blank, to car stereo
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
993
I don't know about the charger, but here's what I picked up for a mount. If you know just about every phone mount, GPS/Garmin/GoPro, etc...
Warlevik
Warlevik
Sweden
THATpurpleKUSH
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
