My finished trunk....PICS
Sleeklsc
Well its all done. The rear deck (up fireing type r's) has been finished for some time now but this weekend i built and carpeted the beauty panel in the trunk, secured the box to seat bolts and regrounded the amp. Took about i'd say 40 min to make and carpet.. 10-12 trips back to the jigsaw to make it a perfect fit.
Before:
After: $1 trunk carpet out of a caddy (junkyard special) i used to cover the panel..Sure beats 15 per yard at the fab shop
Epic, that's awesomeHow does it sound
sounds abit better with the rear deck open. I was going to put my 3 r's back there but they were an inch or 2 to long. I cut the rear upper sheet metal for 3 but only used 2..So i cut the upper panel for 2 aswell...If i switch it up i'll have to get 3 10's to utilize the hole..Then just make another upper panel on my rear deck.
https://batteryhookup.com/products/super-beast-module-with-48-headway-38120-hp-3-2v-8ah-24v
23
7K
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
812
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Sleeklsc
Sleeklsc
AQHDC3
