Music Player for Audison DSP/AMP
  • 2
could i use a dx160, what cable would I need, thanks ?
The dx160 doesn’t have an optical out. It only has analog line out, which can cause interference when using the device or wifi. You would need a very expensive cable to minimize that noise. If you get a DAP that has optical out, you don’t have to worry about that noise as it is eliminated completely as it is mostly reliant on your DAC chip. You could use a relatively cheap optical cable and it’ll be fine, just don’t buy a super long cable and don’t bend or crease the cable as it will compromise the signal.
it looks like it has a coaxial out, would a convertor cause similar interference, thank you
Yes adding a convertor would cause more interference and still would require good cables. Not many devices these days use coaxial anymore. It’s fine to use them but I wouldn’t get a converter box. That would just make things worse. If your dsp/amp has optical inputs then that would be the way to go. Do you have any way of running USB music through your phone or something? That would just make things easier.
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
748
Or maybe this is righter 🤔🤣
811
1997. Wow. They make it to last. vs. American car? Toyota runs pretty efficient. No complaints.
10
Do you have a CD player connected to your Head unit? If so, does it add more voltage drop or use more power that's noticeable? No overheating...
976
What's songs do they play in Costa Rica? Some songs I just like. Even if it's Hard Rock. Like Axl Rose, Guns and Roses. They came to Hawai'i...
40
4K
lewis1962
lewis1962
Sunderland
blazian87
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
